Suite of Automotive Industry Workholding Solutions
Kitagawa NorthTech Inc. announces its suite of automotive industry workholding solutions, which bundles together advanced and custom engineered workholding products for automotive industry machining applications. The advanced workholding series are Kitagawa NorthTech advanced chucks and custom fixtures that have been engineered, modified and/or customized to solve part specific machining for a myriad of automotive industry applications, including camshafts, valves, cylinder pumps and heads, differential cases, brackets, clutches, covers, holders, gears, hubs, pinions, pulleys, rotors, rollers, pistons, and chassis components.
The suite of automotive industry advanced and engineered chucks and workholding for automotive applications includes:
DL200 – Dual locking chuck with increased gripping options and easy jaw forming ideal for high volume automotive machining applications.
PWc and PWTc – 2 or 3 Jaw Power wing chucks with powerful gripping for irregular work pieces and tapered parts. Provides secure gripping for casting and forging applications.
PU Type Pull Lock Chucks (PU, PUB and PUE) – Draw down chucks for high precision processing available with open center types. High radial gripping forces and strong pullback action allows for stable cutting under heavy load conditions.
FG Finger Chucks – for high speed turning of 3 jaw wheel chucks for automotive and motorcycle aluminum wheels and 6 jaw chucks for OTR trucking applications.
Collet Chucks – Short series collet chucks, long series collet chucks, quick change collets chucks and pull back collet chucks.
Custom Fixtures – Weldment or casted base custom fixtures for a variety of horizontal and vertical machining applications.
In situations where a standard and advanced chuck or fixture does not meet the rigid process requirements of a unique part-specific automotive machining application, a fully customized, engineered workholding system may be required. Kitagawa NorthTech's Productivity Team is utilized to help analyze, design, manufacture and test a fully engineered and custom workholding solution for customers. The Productivity Team has the expertise at designing, engineering and manufacturing an extensive range of workholding and tooling for automotive turning and prismatic applications. Kitagawa NorthTech also leverages its in-house manufacturing, engineering, testing and production group to provide a turnkey, integrated solution.
