Super Air Nozzle
Super Air Nozzle
EXAIR Corp.'s new ¾ NPT Stainless Steel Super Air Nozzle delivers 4.5 pounds of strong blowing force for blowoff, cooling and drying applications located in corrosive, high temperature, food and pharmaceutical environments.
September 1, 2010
EXAIR Corp.'s new ¾ NPT Stainless Steel Super Air Nozzle delivers 4.5 pounds of strong blowing force for blowoff, cooling and drying applications located in corrosive, high temperature, food and pharmaceutical environments. The force is more than 5 times that of ordinary air nozzles. It is ideal for blowing heavy materials and where the air nozzle can't be mounted close to the target surface. The aerodynamic design of the ¾ NPT Stainless Steel Super Air Nozzle directs the compressed air to a single point of convergence, delivering a concentrated stream of high velocity airflow with hard-hitting force. Safe operation is assured since the airflow cannot be blocked as required by OSHA standard 29 CFR 1910.242(b). At 80 PSIG, the air consumption is 91 SCFM. The sound level of 96 dBA is below the limits of the OSHA maximum allowable noise exposure standard 29 CFR 1910.95(a). The Type 316 stainless steel construction of this Super Air Nozzle has a 1-¼" (32mm) hex body for easy installation using a standard wrench or socket. Applications include ejection of heavy parts, drying, part and machinery cleaning, chip removal, liquid blowoff, and cooling hot parts. Price is $259.
