SuperStar .01 Filters
LA-MAN Corp. says it has a unique approach to providing filtration for compressed air systems.
LA-MAN Corp. says it has a unique approach to providing filtration for compressed air systems. The patented series of SuperStar .01µm Filters are a four-stage filter designed to operate most effectively within 25 feet of the point of use.
By incorporating a charcoal absorption element, the filter offers a .01µm rating with flow ranges of 50, 75 or 100 SCFM and pressure ratings of 250 psi. The SuperStar .01µm Filter is an ideal solution for an extensive array of applications that require the highest standards of compressed air.
Additional standard features of the SuperStar .01µm Filter include built-in differential pressure gauges providing a visual indication of required maintenance, and an automatic float drain that allows for the discharge of moisture with no electrical requirements.
