TA Angle Head
TA Angle Head
Eliminate secondary operations and increase your machines versatility with a TA Angle Head from OMG. Available in a large variety of profiles and angles, no job is beyond reach.
February 19, 2018
TA Angle Heads are durable and perform better thanks to the quality of our design and the components we use. The body is machined from steel for maximum rigidity with minimal thermal expansion. Precision ground angular contact bearings and Gleason rectified gears give maximum performance with minimal vibration.
With a compact design that delivers high performance, high speed, and long life for a cutting tool, the TA Angle Head is asuitable solution.
