Tag Master 3 Automatic Name Tag Feeder/Marker
The redesigned Tag Master 3 from Kwik Mark Inc. uses dot peen technology to permanently mark industrial components. The automatic feeder/marker was developed to eliminate the problematic tag feeding issues of escaping tags from the bottom of the magazine.
December 21, 2017
The tags are transferred from the top to eliminate the jamming, scratching and other problems associated with bottom feed "coin changer" type escapements. This also means thickness tolerance and sharp edges are no longer issues. Available with Print Queue Driver, allowing multiple users to download job menus, variables and quantities.
