Tank and vessel cleaning nozzle
The BETE HydroClaw (HC) tank and vessel cleaning nozzle from EXAIR features a clog-resistant design, which makes it an ideal solution for industries that demand powerful, maintenance-free tank cleaning, such as breweries, wineries, chemical processing plants, or food processing facilities that use small- to medium-sized tanks.
The HydroClaw is an efficient, hygienic cleaning nozzle engineered to allow particles up to 1/4" in diameter, three times the free passage of comparable spray balls. Large diameter orifices create heavy, straight jets that are dispersed using specially designed deflection cups. With no moving parts, this system delivers consistent cleaning performance while reducing maintenance and downtime. Its low-pressure/high-flow operation quickly cleans tank walls while simultaneously decreasing water consumption. Available with a 360-degree spray angle in food-grade 316L stainless steel and a variety of standard connection types and sizes.
The HydroClaw and many other BETE nozzles are available for immediate purchase. Learn how these and an extensive selection of different liquid and air atomizing nozzles can enhance the efficiency and reliability of your industrial spray applications by visiting EXAIR.com.
