Tank Side Coalescer
Tank Side Coalescer
The Eriez Hydroflow Tank Side Coalescer is designed to sit behind a metalworking shop's machining center and skim free-floating tramp oil out of the machine coolant.
The Eriez Hydroflow Tank Side Coalescer is designed to sit behind a metalworking shop's machining center and skim free-floating tramp oil out of the machine coolant. With a flow rate of 1.5 GPM, this small, inexpensive sump-side coalescing unit allows oils to rise naturally by providing a motionless area not available in a turbulent sump.
Reducing tramp oil is a high priority for all metalworking shops. Excess tramp oil leads to smoke, mist and bacterial infestation of the metalworking fluids, and adversely affects surface finish and reduces tool and dimensional tolerance control. Installing the Eriez Tank Side Coalescer extends the life of coolants and cleaners, improves machining and preserves valuable tools.
The operation of this unit is simple, yet effective. The submersible pump sits inside the coolant tank drawing coolant into the 15-gallon drum. The adjustable skimmer removes any tramp oil off the top layer of coolant. Through a gravity hose, the clean coolant is returned to the machining center sump. This low-maintenance Tank Side Coalescer is available with optional oil belt skimmer, air pump and larger electric pumps.
