TaskMaster Air Cleaner
The TM 1000 TaskMaster from Micro Air Clean Air Systems offers shop and plant air cleaning versatility.
The TM 1000 TaskMaster from Micro Air Clean Air Systems offers shop and plant air cleaning versatility. The TaskMaster is ideal for maintenance and source capture applications virtually anywhere control of pollution is required. An operator simply rolls the TaskMaster 1000 to where it is needed, plugs it in to any 120v single phase outlet, and chooses the attachment necessary to get the job done.
Maximum versatility is built into the TaskMaster. The TaskMaster base unit incorporates a unique "Lift-Off" attachment connection. Attachments can be changed as rapidly as your requirements. Attachments include articulated source capture arms in various sizes, dual articulated arms (for use by two operators), downdraft table, backdraft hood, and long reach flexible hose with hood. These attachments make the TM 1000 TaskMaster a unit capable of source capturing pollutants when grinding, welding, cutting, gluing, painting and more. When conditions change — change the attachment. There's no need to buy a different unit for each application.
Low power requirements allow the unit to be uniquely portableable to be rolled around and plugged into any standard 120v single phase outlet. Optional plug-ins to 208/230v and 460v three phase outlets are available. The unit is powered by an efficient high-capacity motor-blower assembly that provides 1,000 cfm, all within a trim 25 ½" x 35" footprint, so it can be maneuvered in tight areas where limited access is available.
The unit also features dual cartridge filters cleaned by Micro Air's Roto-Pulse high-efficiency cartridge cleaning system, assuring that cartridges clean the air at top efficiency. Filter options are also available; including HO Spunbound cartridges, HEPA 99.97 percent afterfilters to control minute particulate, and activated charcoal modules to control odor.
