TFG20 Fiber Gantry Laser
The TFG20 gantry enclosure is Technifor's latest laser marking solution.
June 12, 2012
The TFG20 gantry enclosure is Technifor's latest laser marking solution. The table (12" x 24" x 6") with its X and Y axis numeric references, simplifies large batch marking and part serialization.
This compact Class 1 laser enclosure (26" x 40" x 18") sits on a bench or cart. The large, ergonomic access door makes it easy to load/unload parts. The versatile 20W fiber laser marks a wide range of materials, including anodized aluminum, stainless steel and most plastics, and readily accommodates many shaped and sized parts.
Technifor's T8000w software, specific for gantry marking, is easy to learn and operate. Once programmed, the onboard control panel simplifies file selection.
