Tiger·tec Gold PVD Grade
This grade is now capable of longer tool life, greater reliability, and approximately 30 percent greater performance in stainless steels (ISO M) and heat-resistant super alloys (ISO S), and up to 75 percent greater performance in steels (ISO P) than comparable grades. With the launch phase now complete, the PVD grade WSP45G Tiger·tec® Gold can be used universally in all standard Walter milling cutters.
August 27, 2022
Walter has introduced its Tiger·tec® Gold PVD grade WSP45G, a new generation of indexable carbide inserts for milling that dramatically expands capabilities for slotting, shoulder, and copy milling. The new grade can efficiently process demanding machining applications such as interrupted cuts and difficult materials.
This new grade is now capable of longer tool life, greater reliability, and approximately 30 percent greater performance in stainless steels (ISO M) and heat-resistant super alloys (ISO S), and up to 75 percent greater performance in steels (ISO P) than comparable grades. With the launch phase now complete, the PVD grade WSP45G Tiger·tec® Gold can be used universally in all standard Walter milling cutters.
The key to the grade's performance is its next generation coating technology and its special layer structure. The gold colored ZrN top layer facilitates exceptional low-friction characteristics as well as excellent wear detection, thus making it possible to utilize the full potential of the indexable insert to extend tool life. Next, multiple layers of aluminum oxide (Al2O3) increase the inserts temperature resistance.
All are applied on top of a TiAlN base layer and a premium carbide substrate as a foundation, greatly increasing the overall wear resistance. These properties make the new inserts ideal for challenging conditions, such as interrupted cuts, long overhangs with a tendency to vibrate, or for wet machining.
  • indexable insert
    Replaceable tool that clamps into a tool body, drill, mill or other cutter body designed to accommodate inserts. Most inserts are made of cemented carbide. Often they are coated wi…
  • stainless steels
  • wear resistance
  • aluminum oxide
