ETEL presents its most well known and best-selling motor worldwide to North America, the ironcore TMB torque motor series. Continuing its reputation of being a worldwide leader in direct drive technology and maintaining the status of having one of the largest market shares for torque motors, the TMB series is a prime example of ETEL's quality in performance and design, and is now available through exclusive distribution by HEIDENHAIN Corp. With 3,500 to 5,000 machines being equipped with TMB motors each year, ETEL proves time and time again the reliability of its products.
The TMB motor series is designed to handle even the most demanding of applications when high torque is required, according to the company. Its caged-structure design enables liquid cooling for heat dissipation and increases its continuous torque past what could be done otherwise. The TMB series also utilizes ETEL's patented design which minimizes the force ripple while maintaining the high-torque density. This will ensure a smooth motion no matter what the speed.
The TMB series comes in 50 standard model sizes with different windings allowing the user to get maximum performance depending on how much torque, current, and speed needs is required. TMB motors can achieve a peak torque of up to 31,200 Nm and achieve speeds of up to 4,500 rpm. It also has the option of coming with ETEL's IMTHP thermal module which, when coupled with ETEL's torque motors, enables users to reduce their amount of safety margins while receiving precise and reliable temperature monitoring. ETEL torque motors are compatible with most CNCs.
The TMB series is designed specifically for direct drive applications and offers the following advantages over transmission-based devices:
• Fewer parts requiring lower overall costs
• Stable performance along the machine's lifetime due to zero maintenance being required
• No backlash, allowing for better accuracy and repeatability
• Smooth, precise, and efficient motions
• Compact design
- backlash
backlash
