TMK Torque Motors
TMK Torque Motors
Available from Heidenhain Corp., ETEL's TMK motor range boasts a unique electromagnetic design and redefines the concept of torque motors at high speeds without necessitating compromises on other performance criteria.
The TMK series is the result of market demand towards a desire for higher speed rotary motors that still maintain the amount of torque provided in other models, such as the ETEL's TMB series, according to the company. Due to its rotor design, which utilizes buried magnet technology along with field weakening, it is reportedly able to rotate with speeds of up to nine times greater than a typical torque motor's standard working speeds. And with the buried magnet technology also providing a higher flux concentration, the TMK series motors can produce up to 30 percent more continuous torque compared to traditional torque motors of the same size. Along with that, it uses liquid cooling to increase its continuous torque even further. And with its patented design minimizing force ripple, the TMK series maintains a high force density while other anti-cogging motor designs sacrifice performance.
Because of its ability to achieve such high speeds, the TMK torque motor series has recently won the Innovation Award in Paris, France at the "Industrie 2014" international industrial fair. The fair's judges, a team composed of about 20 specialized journalists, stated that "The TMK motor is an innovative product enabling new functions in the area of milling and turning in the machine tool industry that will lead to higher technology end products and lower manufacturing costs."
ETEL's TMK torque motors are available in 24 different sizes with six diameters, from 198 to 1050mm, and four heights to cover a range of continuous torque from 80 Nm to 10800 Nm. It is also able to reach a maximum peak torque of up to 20000 Nm. TMKs are well adapted for high-end machine tool applications and rotary tables in which one needs to combine accurate positioning with high torque at low speeds. The TMK series is able to achieve this while being able to switch to a dynamic mode reaching very high speeds at lower torque levels.
The TMK also has the option of ETEL's IMTHP thermal module which enables users to reduce their amount of safety margins while receiving precise and reliable temperature monitoring. ETEL torque motors are compatible with most CNCs.
