The new Tongtai Q5 CNC gang-type lathe from Absolute Machine Tools is a compact, simple machine engineered specifically for fast production of small parts. The Q5 features a 6,000 rpm (optional 8,000 rpm), 7.5 hp (5.6 kW) spindle motor and offers a rapid traverse rate of 1,181 IPM. The compact machine has a 5' x 6' 3" (1,490mm x 1870mm) footprint, and with straightforward gang tooling and no subspindle it is equipped for speed. Tool capacity, depending on the workpiece being processed, is 4-6 ID or OD tools.
Optional automation systems further increase the machine's productivity. A simple, easy-to-operate solution combines a bar feeder, part catcher, and part conveyor. Through-spindle bar capacity is 1" (25mm) -dia. For longer-term, higher-volume automated production, 8-pallet or 2-pallet gantry-loader-type part stockers are offered to handle parts up to 2" (50mm) in diameter and 1.5" (38mm) in length.
- inches per minute ( ipm)
- inner diameter ( ID)
- lathe
lathe
- outer diameter ( OD)
- rapid traverse
rapid traverse
