»toolBalancer« Balancing System
The latest HSC machines work with high speeds and therefore need precisely balanced tools. The ZOLLER »toolBalancer« — the high-precision balancing system specifically for toolholders, grinding wheels and rotors — gives you precisely balanced tools.
The latest HSC machines work with high speeds and therefore need precisely balanced tools. The ZOLLER »toolBalancer« — the high-precision balancing system specifically for toolholders, grinding wheels and rotors — gives you precisely balanced tools, which can be adjusted individually to your requirements, even with future developments, all thanks to its modular design.
This modern balancing system guarantees you a longer, controlled, effective, quick and high-quality production. This measurably reduces your rejection rates, machine downtimes, production costs and lead times.
