Torrent Parts Washer
Torrent Combines Cleaning Power of Heat, Chemistry and Pressure
Torrent combines the triple-action cleaning power of heat, chemistry and pressure for superior results. The Torrent cleans 5X faster than traditional automatic parts cleaners and is 10X more powerful than other cabinet washers. Unlike traditional parts washers that use petroleum or chlorinated solvents, Torrent uses a water-based surfactant blend. This unique, solvent-free approach reduces employee risk while cleaning 90% of parts within one minute.
An environmentally friendlier combination of heat, pressure and chemistry - Unlike traditional parts washers that use petroleum or chlorinated solvents, Torrent uses a water-based surfactant blend. This unique, solvent-free approach to parts washing reduces employee risk while cleaning 90% of parts within one minute.
  • Cleans hard-to-reach points with heat and pressure
  • Up to 5 times faster than traditional automatic parts cleaning
  • Up to 8 times faster than solvent-based manual washing
  • Safer, solvent-free solution
The Torrent Difference
The Problem - Traditional Parts Washers
  • Generally unsafe to use and require PPE due to exposure and splash back of solvents.
  • Cleaning time is increased due to slow manual parts washing with a brush - required for hard-to-reach parts.
  • Not environmentally-friendly.
  • Typically lower pressure - resulting in inefficient cleaning of parts.
The Solution - Torrent
  • Improved productivity
  • Pressure, temperature and chemistry for a faster cleaning
  • Reduces the need for flammable solvents
  • Lowers labor costs
  • Reduces secondary cleaning with aerosols
  • Sealed wash area creates a safer user experience
  • Reduces exposure to harmful solvents
  • Washes all parts safely
The Torrent System
Torrent parts cleaner solves the problems of traditional parts washing with:
Safer Parts Cleaning
Torrents are more cost effective, safer and faster compared to solvent-based parts washers. With the Torrent your staff will no longer be exposed to flammable solvents.
Superior Performance
Torrents combine the joint action of pressure, temperature, and chemistry to work five-times faster than automatic machines. Torrent's unique design clean where an automatic machine cannot. Powerful cleaning solution & corrosion inhibitors allows for the safe washing of all metals and materials.
Economical Operation
Time and time again, a Torrent proves more cost effective than traditional parts washers. In addition to better performance, Torrents cut hazardous waste costs by eliminating the use of solvent-based chemicals. Torrent also reduces labor costs by virtually eliminating the need for secondary cleaning with aerosols.
Triple-Action Cleaning Power
Machine Features
  • Enclosed Spray Area
  • Water Nozzle & Air Blower
  • LED Light
  • Front Lid
  • Gloves
  • Lid Safety
The Torrent system is a unique parts washing solution that stands out in the market place. The Torrent combines the triple-action cleaning power of heat, chemistry and pressure for superior results.
Action 1 - Heat The aqueous cleaning solution is headed to 131°, activating the aqueous cleaners and loosening oils and greases.
Action 2 - Chemistry The aqueous cleaning chemistry is safer for users, produces zero VOCs and lifts deposits from the dirtiest parts. It also leaves behind a rust inhibitor for maximum protection of your cleaned parts.
Action 3 - Pressure Tough deposits are blasted away by the pressure of the Torrent parts washer, which is 10 times more powerful than other cabinet washers. The distinct advantage is that the pressure and solution can be directed by the user into all nooks and crannies that other cabinet washers can’t handle.
