TR200Y Dual-Axis Trunnion Rotary Table
Five-axis machining is a powerful tool for reducing setup time and increasing accuracy for complex parts. But investing in a 5-axis machine tool can be prohibitively expensive, especially for smaller shops. The new TR200Y dual-axis trunnion rotary table from Haas Automation puts 5-axis capabilities well within reach of the average job shop, and its compact size provides greater mounting flexibility.
The TR200Y is designed to mount in the Y direction (front to back on the table) of a mid-size VMC. At less than 27" (686 mm) wide and only 20" (508 mm) deep, the TR200Y easily fits on one end of the machine's table, freeing up the remainder for additional fixtures or vises. The TR200Y has a 200 mm (7.87") T-slot platter, and will swing parts up to 8.1" (206 mm) diameter. The maximum platter capacity is 80 lb (36 kg). The trunnion provides ±120 degrees of tilt and 360 degrees of rotation for full simultaneous 5-axis motion, or to position parts to almost any angle for machining. Yet, like all Haas rotary tables, it can easily be removed when not needed.
Powerful brushless servomotors provide 150 ft-lb (203 Nm) of spindle torque on both axes of the TR200Y. Brake torque is 300 ft-lb (407 Nm) on the tilt axis and 100 ft-lb (136 Nm) on the rotary axis; speeds are 130 deg/sec on the rotary axis and 100 deg/sec on the tilt axis. The trunnion's precision-ground platter of heat-treated 4140 alloy steel has six standard 5/8" (16 mm) T-slots equally spaced at 60 degrees for easy fixturing.
Plug-and-play compatibility makes connecting the TR200Y to a Haas mill with 4th- and 5th-axis drives a breeze, and the available programmable servo control makes it easy to interface the rotary to almost any machine.
