Tramp Oil Separators
MSC Filtration Technologies now offers a standard line of Tramp Oil Separators (TOS) providing extended coolant sump life by removing liquid and solid contaminants that cause coolants to lose their effectiveness.
March 1, 2011
MSC Filtration Technologies now offers a standard line of Tramp Oil Separators (TOS) providing extended coolant sump life by removing liquid and solid contaminants that cause coolants to lose their effectiveness. The proven design allows for removal of tramp oil and solids suspended in the oil for improved tool life, reduced coolant purchases and disposal costs.
Constructed of carbon steel with no internal moving or disposable parts for low maintenance, the TOS units are available as machine mountable, floor mounted and portable to serve multiple machines. Units are equipped to operate as continuous automatic or manual batch oil drain, depending on customer requirements. Models offered have flow rates of 3 and 6 GPM. Custom designed units are also available.
  • tramp oil
