Tri-Cam Countersinks
The new Rocky Mountain Twist Tri-Cam countersinks are designed with high-flow flutes for excellent material evacuations and finely tuned cutting edges for a smoother countersink finish. This results in a smooth, consistent finish for true fastener interface.
December 19, 2016
The countersinks are manufactured from fully hardened steel for optimal cutting edge and thread life and are available in both M2 high-speed tool steel and M42 cobalt. Precision CNC diamond machining insures exact specifications and consistency.
Features include non-marring self-guiding pilot, finely tuned cutting edges that deliver smoother countersink finish, and oversized cross-hole that allows easy countersink removal.
  • countersink
    Tool that cuts a sloped depression at the top of a hole to permit a screw head or other object to rest flush with the surface of the workpiece.
