TRT 83×37 Parts Washing Machining
Walther Trowal's washing machine TRT 83x37 automatically removes thick layers of lubricants like grease, as well as other contaminants, from the surface of disassembled equipment components, which must be perfectly clean before they can be reused for the repair and overhaul of equipment.
After years of operation these components are usually covered with thick layers of grease and dirt. They are simply placed into the vibrating work bowl of the TRT 83x37, which is filled with non-abrasive processing media and a mix of water and degreasing compound. After about 20 to 45 minutes, the components are clean and can be removed.
The TRT 83x37 is suitable for workpieces with lengths of 80 cm (32") and diameters of up to 30 cm (12"). Walther Trowal designed this machine specifically for workshop operations where space is usually tight: It requires less than one square meter (10 square feet), and uses not more energy than a hair drier.
Operation of the machine is fully automatic. It must simply be switched on and off.
