TRT70 Dual-Axis Rotary Table
The TRT70 dual-axis rotary table from Haas Automation delivers high-speed and accurate positioning for 3+2 and full 5-axis machining of small, complex parts – like those found in the medical, dental, and jewelry industries. The unit's ultracompact size and light weight reportedly make the TRT70 the perfect dual-axis solution for even the smallest machining center.
September 23, 2016
The TRT70 uses powerful brushless servomotors to provide 60 ft-lb (81.3 Nm) of torque on the tilt axis and 40 ft-lb (54.2 Nm) on the rotary axis; indexing speeds of 410 deg/sec on the tilt axis and 620 deg/sec on the rotary axis ensure short cycle times. The unit provides ±120 degrees of tilt and 360 degrees of rotation to position parts to almost any angle for machining. The precision-ground 70 mm (2.76") platter features multiple bolt patterns and a precision through-bore for versatile fixturing, and will swing parts up to 4.0" (102 mm) diameter. The maximum platter capacity is 3 lb (1.4 kg).
At just 18.5" (470 mm) wide and 10" (254 mm) deep, the TRT70 easily fits into even the smallest machining center, or can be mounted on one end of a larger machine's table, freeing up the remainder for additional fixtures or vises. It is the perfect complement for Haas Automation's new CM-1 Compact Mill or existing OM-Series Office Mills. Like all Haas rotary tables, the TRT70 can easily be removed when not needed.
  • machining center
