TSLOT Linear Lights
Smart Vision Lights offers its new TSLOT series of linear lights. These lights are 80/20 extrusion adaptive LED light illuminators with an intense and uniform light pattern that offers considerable energy savings over fluorescent lighting, according to the company.
The TSLOT unit slides into the 80/20 brand extrusion with no need for extra mounting accessories. The lights feature a low-voltage 24V DC to keep the installation green, and their ability to direct-connect up to 6 module lengths of 300mm to 1,800mm are achievable in 300mm increments.
Simple to mount and easy to use, the TSLOT lights are ideal for use in applications that include limited-distance or tight areas such as control panes and under-conveyor requirements. They can be used to illuminate robotic work cells by embedding in gating, deployed in welding areas where light is simple to change and substituted for legacy hanging fixtures. The IP-50 rated TSLOT lights mount in most popular T-slot extrusions.
  • extrusion
    extrusion
    Conversion of an ingot or billet into lengths of uniform cross section by forcing metal to flow plastically through a die orifice.
