TungBoreMini Drilling and Turning Tools
Tungaloy unveils TungBoreMini, a multifunctional drilling and turning tool line. TungBoreMini unifies the capabilities of drilling, OD and ID turning tools, allowing significant time saving when changing tools and better utilization of the machine.
TungBoreMini’s insert and pocket feature a dovetail interlocking design that provides better insert clamping and stability during various applications, compared with conventional screw-down insert retention.
Eight holders are offered in diameters 10 mm, 12 mm, 14 mm and 16 mm (0.394", 0.472", 0.551" and 0.630"), each in right- and left-hand models. Inserts are available in four different sizes to fit the corresponding holders.
At a glance:
Multiple machining operations with a single tool: Drilling, OD and ID turning
Significantly reduces machine downtime for improved productivity
Superb insert-pocket interlock enhances insert clamping and stability in a wide range of operations
  • inner diameter ( ID)
  • outer diameter ( OD)
  • turning
