TungdrillTwisted Drill
Tungaloy Corp. announces the expansion of newly designed drill bodies and new insert grades for TungdrillTwisted.
May 1, 2015
Tungaloy Corp. announces the expansion of newly designed drill bodies and new insert grades for TungdrillTwisted. The series has been well-recognized in the market for its excellent cutting performance since its release, according to the company.
The drill bodies deliver even more stability and efficiency in holemaking with high rigidity to withstand the deflection and the optimized balance in insert positions. AH9030 and AH6030 are Tungaloy's newest insert grades for holemaking where wear resistance and anti-oxidation are required. These grades, combined with the stability of the drill body, will deliver long tool life.
This expansion strengthens the TungdrillTwisted series helping customers increase their productivity and reduce machining cost.
Main features:
• Highly rigid drill body increases stability in machining.
• New grades with high wear resistance provide long tool life.
• Rich line-up of tools: Tool diameter ø .500" – ø2" (ø12.5 — ø54.0mm), L/D = 2 — 5
• Four types of chipbreakers are applicable for various workpiece materials. Twisted coolant holes provide excellent chip evacuation.
  • wear resistance
