Turning center with built-in motor spindle
The QTE-200 MSY CNC Turning Center from Mazak was built for speed, precision, and reliability, the company says. The QTE-200MSY's integral 20 hp (15 kW) turning spindle reaches a maximum speed of 5,000 rpm, and the machine processes part diameters up to 13.39" (340 mm) and has a bar diameter capacity of 2.56" (65 mm).
December 5, 2025
The machine accommodates workpieces up to 22.6" (574 mm) in length. Feed axes measure 8.46" (215 mm) in X, 3.94" (100 mm) in Y, and 23.8" (605 mm) in Z, with LM guides on all axes for superior long-term accuracy and repeatability. The rotary tool turret spindle provides 7.38 hp (5.5 kW) milling with a maximum speed of 4,500 rpm and 12-tool capacity.
The QTE-200MSY has a 10 hp (7.5 kW) second spindle capable of 6,000 rpm with a 6" chuck to allow for a Done-in-One process. For reduced maintenance and higher part quality, the headstock design of the QTE-200MSY eliminates belts and pulleys, while the overall machine construction minimizes vibration to produce high-accuracy machining with exceptional surface finishes.
The QTE-200MSY includes the Mazatrol SmoothEz CNC with Mazatrol conversational programming and G-code programming capabilities. For built-in automatic tool presetting, operators simply bring the tool tip in contact with the machine's Automatic Tool Eye, which automatically records the offset of the tool nose position, tool measurement and data registration to ensure accuracy and reduce setup time.
  • conversational programming
    Method for using plain English to produce G-code file without knowing G-code in order to program CNC machines.
  • G-code programming
    Programs written to operate NC machines with control systems that comply with the ANSI/EIA RS-274-D-1980 Standard. A program consists of a series of data blocks, each of which is t…
