Two-Speed Combination Belt and Disc Finishing Machines
The two-speed combination belt and disc finishing machines from Palmgren can handle nearly every finishing operation. Equipped with value-added features, these machines reportedly deliver superior performance with serious results.
May 23, 2017
The machines grind, sand, chamfer, deburr and finish materials efficiently and accurately. The belt feature is mounted directly to an oversized motor shaft for maximum power and efficiency. It comes with a steel back-up platen, a lower drive drum that is ribbed 60 duro rubber-coated for optimized belt traction and a belt head that adjusts vertically, horizontally and to any position in between. The disc section is mounted directly to an oversized motor shaft for added power.
