ULTRA-BOND 2187 Dry-In-Place Pretreatment
Madison Chemical introduces ULTRA-BOND 2187, a dry-in-place pretreatment for precleaned metal. This zero-phosphorus solution forms a homogeneous organic/inorganic layer on pretreated metals, providing outstanding corrosion protection for pretreated surfaces painted with powder or piqued paints.
May 1, 2019
By depositing a molecular layer onto the surface of precleaned metal, this proven dry-in-place solution enhances paint adhesion and corrosion resistance. Utilizing a 1 to 3% concentration for 30 to 90 seconds, it is more cost-effective than traditional alternatives and using it at room temperature substantially reduces energy needs. Additionally, by eliminating the need for post-coating rinse tanks, ULTRA-BOND 2187 significantly reduces water consumption. It is ideal for use with ferrous, aluminum, zinc and stainless alloys when used as directed.
This product may allow users to "de-categorize" as a metal finisher.
Salt Spray performance on cold-rolled steel painted with 1 to 2 mills of polyester powder paint is 336 to 500 hours exposure to ASTM B1117 neutral salt spray.
Madison Chemical Representatives can assist with chemical resistance recommendations on processing tanks, heater exchangers, pipes and pumps.
  • corrosion resistance
