Updated Operator Control Panel for Eldorado Gundrilling Machines
Every new Eldorado gundrilling machine now features an updated operator control panel. While still using a PC-based system featuring Beckhoff controls, both the hardware and software have been improved with job shop operators in mind.
July 29, 2019
The display screen has been enlarged to 7 inches, which allows for larger graphics and easier-to-read menus. Touchscreen capability has also been added to improve menu navigation. Large pushbuttons have replaced the keypad, which makes the control panel more durable and easier to use in a shop floor setting.
The new control also features CNC G-Code programming capability, which allows the customer to write their own gundrilling programs. This improves machine flexibility with options like variable feeds and speeds, drilling peck cycles, dwell times, and many other basic G-Code capabilities. A simple USB connection for an external keyboard makes it easy to quickly type new G-Code programs while standing at the machine.
For shops with older Eldorado machines, the new control is available as a retrofit package.
  • G-code programming
    Programs written to operate NC machines with control systems that comply with the ANSI/EIA RS-274-D-1980 Standard. A program consists of a series of data blocks, each of which is t…
  • gundrilling
    Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
