V-308 Nanopositioning Slide
The closed-loop linear slide uses an optical position sensor with sub nanometer resolution and a voice coil linear motor to allow vertical (or horizontal) travel up to 7mm with a velocity up to 200mm/sec (8"/sec) for fast accurate scanning. Guided by low friction cross-roller bearings, this low-profile linear slide delivers long lasting performance in high duty cycle industrial applications. Ease-of-use is built in with a user-adjustable counterbalance, (e.g. for heavy, large NA microscope objective lenses up to 1kg in vertical applications) and hard stop adjustability to limit the travel range.
May 11, 2021
PI extends its large offering of nanometer precise, fast focusing stages with the addition of its new V-308 nanopositioning slide for vertical applications providing 7mm of Z-travel and 10nm incremental motion – ideal for OEM and research applications in the life science, semiconductor, and material science fields. The novel design combines long travel with unmatched dynamics and precision with 8m/s2 acceleration and 25nm bidirectional repeatability.
Closed-Loop Linear Slide Design with Voice-Coil Motor
  • linear motor
    Functionally the same as a rotary motor in a machine tool, a linear motor can be thought of as a standard permanent-magnet, rotary-style motor slit axially to the center and then p…
