V.0071-gr and V.0141-gr Green Laser Marking Systems
A significant increase in marking speed and marking quality on previously insufficiently markable materials are the main benefits of FOBA's green laser. Affected materials include special plastics like UHMWPE, HDPE or PMMA for which additives might no longer be necessary, as well as glass or shiny substrates. Compared to other laser types like UV or fiber, the green laser shows better marking results while achieving superior marking speeds.
November 4, 2022
FOBA has developed a 532 nanometers wavelength green laser marking system which offers new possibilities for industrial direct part marking. Supplemented by FOBA's comprehensive marking workflow, the low heat laser applies perfect marks on materials with extraordinary absorption properties. Such materials include white, transparent, or red plastics as well as highly reflective metals. The green laser completes the range of laser wavelengths in FOBA's portfolio of marking systems.
The application of the green laser marker can be facilitated using FOBA's proven laser marking workflow with camera and mark alignment software. "The optical part inspection and validation of marked contents as well as the automated and precise positioning of the laser mark have long been valued by our customers as a reliable and safe workflow solution", says Philipp Febel, director product management at FOBA. "Our green laser can easily be equipped with various laser alignment tools and works with any of the available FOBA user interfaces."
The FOBA V.0071-gr and FOBA V.0141-gr green laser marking systems close the gap between UV (355 nm)- and fiber (1,064 nm)-laser markers. The combination of relatively high laser power and a vanadate source enables extended applicability and high speed. "Based on customer requirements, we have developed a leading- edge marking solution with to address the most challenging marking applications", says Philipp Febel.
The new marking laser is available with either 7- or 14-watt laser power variations. It can flexibly be integrated into production environments due to a smaller marking unit (compared to the UV-laser), a broad range of available interfaces and five possible marking field sizes. The lifetime of FOBA's green laser vanadate laser source is twice the lifetime of a UV laser source, which minimizes the total cost of ownership.
