VersatileLock Vises Expanded Line
Kurt's VersatileLock Vises provide clamping repeatability, assuring 0.0005 inch repeating accuracy.
August 1, 2015
Kurt's VersatileLock Vises provide clamping repeatability, assuring 0.0005 inch repeating accuracy. The line up of 20 VersatileLock Vise models includes convenient Reverse Models for part programming in the "Y" axis and easier part loading/unloading. The VersatileLock Vises are also available in models for hydraulic, manual and pneumatic actuation to fit the application.
The combination of the Anglock and the pull-type design in VersatileLock Vises creates an equalizing force between the moveable jaw so the one-piece vise body with integral stationary jaw, holding the workpieces in a rigid and immobile state. Solid, one-piece bodies designed of 80,000 PSI ductile iron with machined steel components dampens cutter induced and machine table vibrations to achieve high cutting speeds and aggressive hogging operations.
With matched body height and matched stationary jaw to keyway dimensioning, programmers and machinists are assured of consistent vise ganging so that part-to-part moves are accurate and won't cause tool collision. VersatileLock Vises are for mounting on either side, on the base or back-to-back making them flexible to achieve the desired holding configuration.
