![Vise Jaws Vise Jaws Can Be Machined to Match Contours and Curves of Workpiece](/sites/default/files/styles/product_image/public/product_images/Dillon%20Vise%20Jaws%20with%20Carbinite%20Coating.jpg?itok=RUdHsRvc)
Dillon Manufacturing, Inc. introduces vise jaws with exacting tolerances (+/- .002” in all dimensions, including flatness), with machined work surfaces to fit the contours and curves of the workpieces. Available in 1018 steel, stainless, 6061 aluminum, or specified alloy materials, in standard or custom blanks. Soft jaws or hardened (heat treated) jaws in HD or HDL vises. Made in the USA in ISO 9001:2015 facilities, with industry leading lead-times. Dillon Vise Jaws are available with industry standard hole patterns that fit most manufactured vises including Chick, Kurt, TE-Co, Toolex, and Palmgren.
Carbinite coating can be added for improved gripping after the Vise Jaws are machined to specifications. Comprised of wear resistant carbide alloys that increase grip to enhance mill performance, Carbinite coatings display exceptional bond strength without annealing or distortion.
- alloys
alloys
- annealing
annealing
Softening a metal by heating it to and holding it at a controlled temperature, then cooling it at a controlled rate. Also performed to produce simultaneously desired changes in other properties or in the microstructure. The purposes of such changes include improvement of machinability, facilitation of cold work, improvement of mechanical or electrical properties and increase in stability of dimensions. Types of annealing include blue, black, box, bright, full, intermediate, isothermal, quench and recrystallization.
- milling machine ( mill)
