Visorguard-LED
Visorguard-LED
Flexbar's Visorguard-LED™ system is water and coolant proof and installs in minutes on CNC mills, conventional mills, drill presses and more. The adjustable Flexbar® arm permits setting of the Visorguard shield at the correct height and angle for each setup, then locks rigid. The special wing-shaped shield flips up to load a part and down for machining. A special spring-loaded shaft allows the shield to stay put with no spring back.
Flexbar Machine Corporation (Islandia, NY) introduces its new line of state-of-the-art Machine Safety Guards featuring Built-in LED Lighting providing machine operators with super bright illumination of the working field. The Visorguard-LED's unique Continuous LED strip lighting is integrated as part of the safety shield providing 6000K natural white light with a 170 degree beam angle. Auto-Diffuse lighting produces no LED light hot spots.
The built-in Visorguard-LED™ lighting is powered through a choice of two available system options:
- A compact 12V Rechargeable Battery Pack with on/off switch provides at least 4 hours of lighting per charge. It can be easily attached to side wing of the shield with included Velcro strips. 12V charger is also included.
- System can be powered through a 12V direct wire wall transformer with 8-foot cable and on/off switch.
Replacement Visorguard-LED™ shields and power kits are available for current Flexbar Visorguard users who can conveniently upgrade their current system to LED lighting.
