VITRA Vitrified-Bond Grinding Wheels
VITRA represents the latest generation of vitrified-bonded Hermes precision grinding tools. This newest achievement of the Hermes research laboratories is based on an advanced high-performance, low-fired bond and an optimized microstructure.
April 19, 2016
VITRA grinding wheels are available in in all aluminum-oxide abrasive types, including sintered aluminium-oxide grain and grit sizes up to 200.
Benefits:
  • Optimized pore structure to increase the intake of coolant and improved chip removal.
  • Significantly low temperature stress during grinding and, thus, shorter grinding times with higher material-removal rates.
  • Universal use with fused and sintered aluminum oxide.
  • aluminum oxide
  • microstructure
    Structure of a metal as revealed by microscopic examination of the etched surface of a polished specimen.
