VL 2P Vertical Turning Machine
The VL 2 P is a two-spindle vertical turning machine with pendulum technology from EMAG is for parts that have a diameter of up to 100mm.
March 12, 2012
The VL 2 P is a two-spindle vertical turning machine with pendulum technology from EMAG is for parts that have a diameter of up to 100mm. One benefit of the VL 2 P is reducing idle times. Idle times due to loading and unloading have been almost completely eliminated. The machine is ideal for workpieces with short machining times since the ratio of machining time to idle time is vital for the cost of the process.
  • turning machine
    Any machine that rotates a workpiece while feeding a cutting tool into it. See lathe.
