Vomat UBF Vacuum Band Filter
The Vomat UBF concept is a vacuum band filter equipped to handle a wide variety of sludge materials, such as ceramic, HSS, brass, aluminum oxide and disc abrasion.
October 1, 2019
It operates with oil as well as water-miscible coolants. In some instances and if necessary it can be combined with a Vomat fine filtration unit.
It is currently available in three sizes with the following filtration capacities: 110 gal. /min., 264 gal. /min. and 528 gal. /min. As with all Vomat designs, the UBF system has a small foot print for its capacity.
  • aluminum oxide
