VP Series Performance Plus Miniature Spiral Bevel Gearboxes
The VP Series Performance Plus miniature spiral bevel gearboxes pack high performance in a small package with a high torque density, range of ratios and torque capacity.
• Sizes 27, 33 and 45 mm
• Highest torque density for the size
• Ratios 1:1 to 4:1
• 98 percent efficiency
• Hollow output option (33 and 45 mm)
The miniature VP Series are suitable for all your miniature automation applications, such as medical and semiconductor, when high performance is required and space is at a premium. The housings are manufactured from high-strength aluminum for a gearbox that is light weight, dissipates heat efficiently and resists corrosion.
