VPFL4 Vacuum Lifter
VPFL4 Vacuum Lifter
A compact, below-the-hook vacuum lifter that is designed for handling heavy pipe or tube from the top, in and out of containers, without using slings or hooks, is being introduced by Anver Corp.
August 1, 2011
The Anver VPFL4 Vacuum Lifter for heavy pipe and tube features nylon centering guides and oval rubber suction cups to prevent anything other than nylon or rubber from touching the load. Designed to compensate for unevenly packed loads with staggered rows, it has a 500 lb. capacity and can pick up 2, 3, or 4 pipes or tubes from the top simultaneously.
Eliminating hooks, slings, and excessive handling that can cause damage, the Anver VPFL4 Vacuum Lifter for heavy pipe and tube is offered in air-powered or electric units that only need 8" of headroom. Standard features include an all-welded steel frame, adjustable handle with built-in controls, a vacuum gauge, and audio-visual vacuum leakage detector system.
The Anver VPFL4 Vacuum Lifter for heavy pipe and tube is priced from $2,995.00. Price quotations are available upon request.
