VR-3000 Series 3D Measurement System
Keyence Corp. has released a new model of its VR-3000 Series. The new VR-3000 Series allows an instant, noncontact 3D scan of a wide area, which has been difficult to achieve with conventional methods. The new model can easily measure rough surfaces, flatness, warpness and planarity.
May 13, 2016
Keyence Corp. has released a new model of its VR-3000 Series. The new VR-3000 Series allows an instant, noncontact 3D scan of a wide area, which has been difficult to achieve with conventional methods. The new model can easily measure rough surfaces, flatness, warpness and planarity. Anyone can measure instantly and accurately; just place the sample on the stage and click a button.
New Functions:
1. Measure and compare multiple samples.
The VR-3000 Series can perform batch analyses between multiple samples simultaneously under the same condition.
2. Compare with CAD data and quantify surface shape differences.
The VR-3000 Series can compare measurement results directly to CAD data. You can compare visual and numerical differences between design data and an actual sample, then export the scan back into CAD data.
3. Pass/Fail inspection.
The VR-3000 Series can automatically determine if a part is good or bad based on user-defined tolerances.
