Vulcan Compression Endmills
Kyocera's new Vulcan compression endmills are for routing composites. The Vulcan compression endmill is designed with up-cut and down-cut flutes to compress the composite material, preventing delamination.
The spiral flute design creates a shearing action to cleanly cut the fibers. Utilizing a positive rake angle, the compression endmill makes quick, sharp cuts, minimizing heat and preventing the formation of resin burrs.
