W26-230
W26-230
Metabo Corp. has introduced a new large angle grinder to its Metabo Metal Masters series, the W26-230.
Metabo Corp. has introduced a new large angle grinder to its Metabo Metal Masters series, the W26-230. The grinder features a newly designed diagonal fan that pulls air across the motor for optimized air flow and cooler operation. Combined with its powerful operation, the W26-230 is ideal for the prolonged cutting and grinding large areas of metal safely and efficiently.
Equipped with a 9" wheel, the W26-230 delivers 159 inch-lbs of torque and a no-load speed of 6,600 rpm. This large angle grinder is reportedly one of the most efficient on the market, featuring a long-lasting 15 A motor with 2,400 W of power and 4.7 hp.
The W26-230 includes Metabo's VibraTech (MVT) three-position side handle that significantly reduces vibration levels up to 60 percent. The side handle also allows users to turn the tool 90 degrees to cut vertically, while still having a firm grasp on the grinder.
The grinder's ergonomic rear handle includes a vibration dampening system and twists into three different positions for comfort during cutting, while reducing user fatigue. The tool includes Metabo's simplified on/off switch configuration with a safety lock-out switch, a burst-proof guard with seven positions and a spindle lock. The W26-230 features a double winding protection grid that deflects harmful airborne debris away from the armature windings as well as auto-stop "COLD" carbon brushes that increase the tool's service life.
