Sumitomo Electric Carbide Inc.'s new WGX Wave Mill Series, used for all facemilling applications, features excellent surface finish and eliminates burrs due to a unique insert chipbreaker design. The WGX body and insert combination yields improved run-out accuracy. Additional WGX benefits include lower cutting force due to its high rake angle and optimized edge treatment for long tool life with new Super ZX and Super FF coatings.
In addition to the WGX Milling Series, Sumitomo Electric Carbide Inc. announces the release of ACM200 and ACM300 insert grades for exotic and stainless steel material milling. The ACM200, which is a CVD grade, offers excellent wear and heat resistance and is suitable for hardened material milling, according to the company. The ACM300, which is a PVD grade, features highly balanced wear and fracture resistance and is the company's first recommendation for stainless steel milling.
- chemical vapor deposition ( CVD)
- chipbreaker
chipbreaker
Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
- cutting force
cutting force
- facemilling
facemilling
- milling machine ( mill)
- rake
rake
