Wohlhaupter NOVITECH Vibration-Dampened Intermediate Module
Allied Machine & Engineering announces the availability of its new Wohlhaupter NOVITECH vibration-dampened intermediate module, which increases boring operations productivity, surface quality and process reliability while extending the insert and machine center's spindle life.
Mounted inside the patent-pending NOVITECH system, the viscoelastically mounted damper modules reduce vibrations during the machining of diameters from 1.97" to 8.07" (50mm to 205mm), up to 10 diameters deep. The NOVITECH intermediate modules feature Wohlhaupter's MultiBore system (MVS), making it simple to use with existing Wohlhaupter components and is compatible with any machine spindle.
