X-treme Jet External Thread Turning Toolholder
Designed for more effective coolant flow and improved chip control, Carmex’s new X-treme Jet External thread turning toolholder provides two connecting options via an elbow fitting and top clamp to more precisely direct the coolant flow to the cutting edge, where it is most effective.
Available in both RH and LH configurations, the X-treme Jet is coated for maximum abrasive resistance. Ideal for high-pressure coolant applications, the directed flow reduces cutting edge temperature, resulting in higher performance, improved chip flow and longer tool life.
Jim White, national sales manager for Carmex USA, comments: “Putting a newer high-quality insert in a traditional toolholder is like installing a custom-built engine in an older car. To achieve maximum insert performance, it’s necessary to select the right combination of tool and toolholder. The new X-treme Jet is designed to optimize cutting performance, while providing the additional efficiencies of improved coolant effectiveness and longer tool life.”
  • abrasive
    abrasive
  • coolant
  • toolholder
    toolholder
  • turning
