XPS-16+ CNC Drilling Sharpener
Darex LLC has recently unveiled the XPS-16+ CNC drill sharpener. This unit can sharpen 2-flute HSS, cobalt, carbide and TiN-coated bits from 3mm to 16mm in diameter.
March 28, 2016
Additionally, the 4-axis unit sharpens everything from common split point geometries to complex 4-facet point drills through an easy-to-use interface. With the ability to store up to 100 drill files, the XPS-16+ is targeted for precision-concise toolrooms.
