Yasda YBM 640V3 3-axis CNC jig borer
Methods Machine Tools Inc. offers the Yasda YBM 640V3 3-axis CNC jig borer for high-speed boring and milling of critical, complex components, such as molds and dies.
February 1, 2014
Methods Machine Tools Inc. offers the Yasda YBM 640V3 3-axis CNC jig borer for high-speed boring and milling of critical, complex components, such as molds and dies. A reinforcement rib under the bridge enhances rigidity and minimizes vibration during acceleration and deceleration, and hand-scraped alignment of box ways through-hardened to 60 HRC provides mechanical accuracy, according to the company. To reduce thermal distortion, there is a bridge cooling system under the X-axis guide, and a jacket cooling system for the X- and Y-axis ball nuts to prevent loss of ballscrew pretension. A 24,000-rpm spindle is standard; a 30,000 rpm version is optional. The table is 27.5"×17.7" (700mm × 450mm), with a table load capacity of 661 lbs. (300 kg). The X-axis travel is 23.6" (600mm), Y-axis travel is 15.7" (400mm) and Z-axis travel is 13.8" (350mm). The toolchanger/" data-glossary-id="142091" data-glossary-teaser="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" title="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" aria-label="Glossary: toolchanger/" data-glossary-id="142091" data-glossary-teaser="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" title="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" aria-label="Glossary: automatic toolchanger">automatic toolchanger">automatic toolchanger stores up to 100 tools.
  • automatic toolchanger
  • toolchanger
