Yaw-Tilt Rotary System
IntelLiDrives Inc. offers the yaw-tilt rotary system. The integrated 2-axis rotary assembly provides high-speed micromachining capabilities for complex 3D part geometries and for general testing, purpose pointing, scanning and tracking applications for small optics, antennae and other sensors. The precision-aligned system allows accurate positioning on a hemispherical surface.
System is equipped with high performance rotary stages and offer excellent stiffness and load capacity making them suitable for a wide variety of applications and motorized with high torque NEMA 17 stepper motors.
Optionally, can be equipped with rotary encoders mounted to the back of the stepper motor to provide closed loop servo performance with IntelLiDrives ServoStep controllers.
  • stiffness
    stiffness
