Dr. Jeffrey Badger, the host of Cutting Tool Engineering magazine's Grinding Doc Video Series, fields a question from a shop truing its diamond wheels offline, then remounting them onto the non-tapered spindle without using an adapter. The shop wondered whether its tight wheel tolerances negate the need for an adapter in the 31st episode of the video series.
About the Grinding Doc Video Series: Thanks to his work as an independent grinding consultant and the author of the "Ask the Grinding Doc" column in Cutting Tool Engineering magazine, Dr. Jeffrey Badger routinely receives questions about grinding from shops all over the world. Through the magazine column and this video series, he provides shops with the insight and guidance they seek.
For more information about the Grinding Doc, visit his website here.
- grinding
- truing
truing
Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
