Cutting Tool Engineering's April 2022 issue includes a feature article about double-sided inserts and high-feed indexable insert milling tools that can help reduce production costs. To supplement this report online, CTE will host a webinar at 10 a.m. (CST) on Wednesday, April 20, titled "Ask The Experts: Indexable Inserts." Robert Bokram, cutting tools product manager with Ceratizit USA will take a deeper dive into recent technological advancements that now allow toolmakers to produce inserts that they "could only dream about in the past." Moderating the webinar will be Keith Jennings, CTE’s long-time Machinist’s Corner columnist and former president of Crow Corp., a family owned machine shop located in Tomball, Texas.
- indexable insert
indexable insert
