A shop seeks relief from the burn experienced during its creep-feed grinding operations. Given that slowing down the feed rate only helped a little, and only for a short time, the shop sought an alternative solution from Dr. Jeffrey Badger, the host of Cutting Tool Engineering's Grinding Doc Video Series.
About the Grinding Doc Video Series: Thanks to his work as an independent grinding consultant and the author of the "Ask the Grinding Doc" column in Cutting Tool Engineering magazine, Dr. Jeffrey Badger routinely receives questions about grinding from shops all over the world. Through the magazine column and this video series, he provides shops with the insight and guidance they seek.
For more information about the Grinding Doc, visit his website here.
- creep-feed grinding
creep-feed grinding
Grinding operation in which the grinding wheel is slowly fed into the workpiece at sufficient depth of cut to accomplish in one pass what otherwise would require repeated passes. See grinding.
- feed
- grinding
- relief
relief
