Horn USA's Adrian Noonan, technical specialist, tours kiosk after kiosk at the Horn booth during Eastec 2023, highlighting the newest innovations for broaching, narrow width slot milling cutters, form boring and internal grooving.
- boring
boring
- broaching
broaching
Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
- grooving
grooving
